查看: 2327|回复: 2
[基本模块类] 求: MATLAB/Simulink 高人!!!
发表于 2011-5-14 14:31 | 显示全部楼层 |阅读模式
Evaluation of expression resulted in an invalid output. Only finite double vector or matrix outputs are supported
function [ff]=myfun(u)
Alpha_2=u(1);Omega_2=u(2);Theta_2=u(3);
Omega_3=u(4);Theta_3=u(5);
Omega_4=u(6);Theta_4=u(7);  %定义输入的变量
global rs_1 rs_2 rs_3 rs_4
rs_1=304.8;
rs_2=101.6;
rs_3=254.0;
rs_4=177.8;
ff(1)=(-(Omega_2)^2*(rs_2)*cos((Theta_2)-(Theta_4))-(Omega_3)^2*(rs_3)*cos((Theta_3)-(Theta_4))+(Omega_4)^2*(rs_4))/((rs_3)*sin((Theta_3)-(Theta_4)));
ff(2)=((Omega_2)^2*(rs_2)*cos((Theta_2)-(Theta_3))-(Omega_4)^2*(rs_4)*cos((Theta_4)-(Theta_3))+(Omega_3)^2*(rs_3))/((rs_4)*sin((Theta_4)-(Theta_3)));
ff=[ff(1) ff(2)];
该段程序是Simulink仿真模块中MATLAB Function中的!
发表于 2011-5-15 11:34 | 显示全部楼层
看看 ff是否正确 还有把最后一行去掉
发表于 2011-5-17 15:43 | 显示全部楼层
支持楼上
是或否分母太小了,还是在matlab调试一下,比较好!
GMT+8, 2024-11-25 01:52 , Processed in 0.082010 second(s), 18 queries , Gzip On.
