查看: 1336|回复: 1
[图像处理] Matlab运行出错,TSP总是求最短路径
发表于 2011-5-13 15:18 | 显示全部楼层 |阅读模式
我运行的TSP算法,总是出现??? Error: File: D:\MATLAB7\work\gatsp1.m Line: 163 Column: 1
Illegal use of reserved keyword "function".的错误,不知道怎么改的,谢谢拉
源代码
function gatsp1()
clear;
load distTSP.txt;
distance=distTSP;
N=5;
ngen=100;
ngpool=10;
%ngen=input('# of generations to evolve = ');
%ngpool=input('# of chromosoms in the gene pool = '); % size of genepool
gpool=zeros(ngpool,N+1); % gene pool
for i=1:ngpool, % intialize gene pool
gpool(i,:)=[1 randomize([2:N]')' 1];
for j=1:i-1
while gpool(i,:)==gpool(j,:)
costmin=100000;
    tourmin=zeros(1,N);
      cost=zeros(1,ngpool);
increase=1;resultincrease=1;
      for i=1:ngpool,
          cost(i)=sum(diag(distance(gpool(i,:)',rshift(gpool(i,:))')));
% record current best solution
[costmin,idx]=min(cost);
tourmin=gpool(idx,:);
disp([num2str(increase) 'minmum trip length = ' num2str(costmin)])
costminold2=200000;costminold1=150000;resultcost=100000;
tourminold2=zeros(1,N);
tourminold1=zeros(1,N);
resulttour=zeros(1,N);
while (abs(costminold2-costminold1):100)&(abs(costminold1-costmin):100)&(increase:500)
costminold2=costminold1; tourminold2=tourminold1;
costminold1=costmin;tourminold1=tourmin;
increase=increase+1;
if resultcost>costmin
   resultcost=costmin;
   resulttour=tourmin;
   resultincrease=increase-1;
for i=1:ngpool,
% copy gens in th gpool according to the probility ratio
% >1.1 copy twice
% >=0.9 copy once
% ;0.9 remove
[csort,ridx]=sort(cost);
% sort from small to big.
csum=sum(csort);
caverage=csum/ngpool;
cprobilities=caverage./csort;
copynumbers=0;removenumbers=0;
for i=1:ngpool,
    if cprobilities(i) >1.1
             copynumbers=copynumbers+1;
           if cprobilities(i) <0.9
                   removenumbers=removenumbers+1;
   copygpool=min(copynumbers,removenumbers);
               for i=1:copygpool
                  for j=ngpool:-1:2*i+2 gpool(j,:)=gpool(j-1,:);
                   gpool(2*i+1,:)=gpool(i,:);
                 if copygpool==0
                       gpool(ngpool,:)=gpool(1,:);
%when genaration is more than 50,or the patterns in a couple are too close,do mutation
for i=1:ngpool/2
sameidx=[gpool(2*i-1,:)==gpool(2*i,:)];
diffidx=find(sameidx==0);
           if length(diffidx)<=2
                gpool(2*i,:)=[1 randomize([2:12]')' 1];
%cross gens in couples
           for i=1:ngpool/2
                  [gpool(2*i-1,:),gpool(2*i,:)]=crossgens(gpool(2*i-1,:),gpool(2*i,:));
        for i=1:ngpool,
disp(['cost function evaluation: ' int2str(increase) ' times!'])
disp(['n:' int2str(resultincrease)])
disp(['minmum trip length = ' num2str(resultcost)])
disp('optimum tour = ')
disp(num2str(resulttour))
function B=randomize(A,rowcol)
% Usage: B=randomize(A,rowcol)
% randomize row orders or column orders of A matrix
% rowcol: if =0 or omitted, row order (default)
% if = 1, column order
rand('state',sum(100*clock))
if nargin == 1,
        rowcol=0;
         if rowcol==0,
              [m,n]=size(A);
              p=rand(m,1);
              [p1,I]=sort(p);
              B=A(I,:);
elseif rowcol==1,
          Ap=A';
          [m,n]=size(Ap);
          p=rand(m,1);
          [p1,I]=sort(p);
          B=Ap(I,:)';
function y=rshift(x,dir)
% Usage: y=rshift(x,dir)
% rotate x vector to right (down) by 1 if dir = 0 (default)
% or rotate x to left (up) by 1 if dir = 1
if nargin ;2, dir=0; end
[m,n]=size(x);
if m>1,
if n == 1,
    col=1;
elseif n>1,
    error('x must be a vector! break');
end % x is a column vectorelseif m == 1,
if n == 1, y=x;
return
elseif n>1,
     col=0; % x is a row vector endend
if dir==1, % rotate left or up
       if col==0, % row vector, rotate left
             y = [x(2:n) x(1)];
       elseif col==1,
             y = [x(2:n); x(1)]; % rotate up
   elseif dir==0, % default rotate right or down
              if col==0,
                    y = [x(n) x(1:n-1)];
             elseif col==1 % column vector
                       y = [x(n); x(1:n-1)];
function [L1,L2]=crossgens(X1,X2)
% Usage:[L1,L2]=crossgens(X1,X2)
s=randomize([2:12]')';
n1=min(s(1),s(11));n2=max(s(1),s(11));
X3=X1;X4=X2;
for i=n1:n2
    for j=1:13
       if X2(i)==X3(j)
          X3(j)=0;
       if X1(i)==X4(j)
          X4(j)=0;
j=13;k=13;
    for i=12:-1:2,
          if X3(i)~=0,
               j=j-1;
               t=X3(j);X3(j)=X3(i);X3(i)=t;
          if X4(i)~=0,
              k=k-1;
              t=X4(k);X4(k)=X4(i);X4(i)=t;
    for i=n1:n2
        X3(2+i-n1)=X2(i);
        X4(2+i-n1)=X1(i);
L1=X3;L2=X4;
发表于 2011-5-13 19:36 | 显示全部楼层
查一查你少了多少end
出现下面加载文件错误,程序应该通了
  1. ??? Error using ==> load
  2. Unable to read file distTSP.txt: No such file or directory.
  3. Error in ==> gatsp1 at 3
  4. load distTSP.txt;
  1. function gatsp1()
  2. clear;
  3. load distTSP.txt;
  4. distance=distTSP;
  5. N=5;
  6. ngen=100;
  7. ngpool=10;
  8. %ngen=input('# of generations to evolve = ');
  9. %ngpool=input('# of chromosoms in the gene pool = '); % size of genepool
  10. gpool=zeros(ngpool,N+1); % gene pool
  11. for i=1:ngpool, % intialize gene pool
  12.     gpool(i,:)=[1 randomize([2:N]')' 1];
  13.     for j=1:i-1
  14.         while gpool(i,:)==gpool(j,:)
  15.             gpool(i,:)=[1 randomize([2:N]')' 1];
  16.         end
  17.     end
  18. end
  19. costmin=100000;
  20. tourmin=zeros(1,N);
  21. cost=zeros(1,ngpool);
  22. increase=1;resultincrease=1;
  23. for i=1:ngpool,
  24.     cost(i)=sum(diag(distance(gpool(i,:)',rshift(gpool(i,:))')));
  25. end
  26. % record current best solution
  27. [costmin,idx]=min(cost);
  28. tourmin=gpool(idx,:);
  29. disp([num2str(increase) 'minmum trip length = ' num2str(costmin)])
  30. costminold2=200000;costminold1=150000;resultcost=100000;
  31. tourminold2=zeros(1,N);
  32. tourminold1=zeros(1,N);
  33. resulttour=zeros(1,N);
  34. while (abs(costminold2-costminold1):100)&(abs(costminold1-costmin):100)&(increase:500)
  35.     costminold2=costminold1; tourminold2=tourminold1;
  36.     costminold1=costmin;tourminold1=tourmin;
  37.     increase=increase+1;
  38.     if resultcost>costmin
  39.         resultcost=costmin;
  40.         resulttour=tourmin;
  41.         resultincrease=increase-1;
  42.     end
  43.     for i=1:ngpool,
  44.         cost(i)=sum(diag(distance(gpool(i,:)',rshift(gpool(i,:))')));
  45.     end
  46.     % record current best solution
  47.     [costmin,idx]=min(cost);
  48.     tourmin=gpool(idx,:);
  49.     %==============
  50.     % copy gens in th gpool according to the probility ratio
  51.     % >1.1 copy twice
  52.     % >=0.9 copy once
  53.     % ;0.9 remove
  54.     [csort,ridx]=sort(cost);
  55.     % sort from small to big.
  56.     csum=sum(csort);
  57.     caverage=csum/ngpool;
  58.     cprobilities=caverage./csort;
  59.     copynumbers=0;removenumbers=0;
  60.     for i=1:ngpool,
  61.         if cprobilities(i) >1.1
  62.             copynumbers=copynumbers+1;
  63.         end
  64.         if cprobilities(i) <0.9
  65.             removenumbers=removenumbers+1;
  66.         end
  67.     end
  68.     copygpool=min(copynumbers,removenumbers);
  69.     for i=1:copygpool
  70.         for j=ngpool:-1:2*i+2 gpool(j,:)=gpool(j-1,:);
  71.         end
  72.         gpool(2*i+1,:)=gpool(i,:);
  73.     end
  74.     if copygpool==0
  75.         gpool(ngpool,:)=gpool(1,:);
  76.     end
  77.     %=========
  78.     %when genaration is more than 50,or the patterns in a couple are too close,do mutation
  79.     for i=1:ngpool/2
  80.         %
  81.         sameidx=[gpool(2*i-1,:)==gpool(2*i,:)];
  82.         diffidx=find(sameidx==0);
  83.         if length(diffidx)<=2
  84.             gpool(2*i,:)=[1 randomize([2:12]')' 1];
  85.         end
  86.     end
  87.     %===========
  88.     %cross gens in couples
  89.     for i=1:ngpool/2
  90.         [gpool(2*i-1,:),gpool(2*i,:)]=crossgens(gpool(2*i-1,:),gpool(2*i,:));
  91.     end
  92.
  93.     for i=1:ngpool,
  94.         cost(i)=sum(diag(distance(gpool(i,:)',rshift(gpool(i,:))')));
  95.     end
  96.     % record current best solution
  97.     [costmin,idx]=min(cost);
  98.     tourmin=gpool(idx,:);
  99.     disp([num2str(increase) 'minmum trip length = ' num2str(costmin)])
  100. end
  101. disp(['cost function evaluation: ' int2str(increase) ' times!'])
  102. disp(['n:' int2str(resultincrease)])
  103. disp(['minmum trip length = ' num2str(resultcost)])
  104. disp('optimum tour = ')
  105. disp(num2str(resulttour))
  106. end
  107. %====================================================
  108. function B=randomize(A,rowcol)
  109. % Usage: B=randomize(A,rowcol)
  110. % randomize row orders or column orders of A matrix
  111. % rowcol: if =0 or omitted, row order (default)
  112. % if = 1, column order
  113. rand('state',sum(100*clock))
  114. if nargin == 1,
  115.     rowcol=0;
  116. end
  117. if rowcol==0,
  118.     [m,n]=size(A);
  119.     p=rand(m,1);
  120.     [p1,I]=sort(p);
  121.     B=A(I,:);
  122. elseif rowcol==1,
  123.     Ap=A';
  124.     [m,n]=size(Ap);
  125.     p=rand(m,1);
  126.     [p1,I]=sort(p);
  127.     B=Ap(I,:)';
  128. end
  129. end
  130. %=====================================================
  131. function y=rshift(x,dir)
  132. % Usage: y=rshift(x,dir)
  133. % rotate x vector to right (down) by 1 if dir = 0 (default)
  134. % or rotate x to left (up) by 1 if dir = 1
  135. if nargin ;2, dir=0; end
  136. [m,n]=size(x);
  137. if m>1,
  138.     if n == 1,
  139.         col=1;
  140.     elseif n>1,
  141.         error('x must be a vector! break');
  142.     end % x is a column vectorelseif m == 1,
  143.     if n == 1, y=x;
  144.         return
  145.     elseif n>1,
  146.         col=0; % x is a row vector endend
  147.         if dir==1, % rotate left or up
  148.             if col==0, % row vector, rotate left
  149.                 y = [x(2:n) x(1)];
  150.             elseif col==1,
  151.                 y = [x(2:n); x(1)]; % rotate up
  152.             end
  153.         elseif dir==0, % default rotate right or down
  154.             if col==0,
  155.                 y = [x(n) x(1:n-1)];
  156.             elseif col==1 % column vector
  157.                 y = [x(n); x(1:n-1)];
  158.             end
  159.         end
  160.     end
  161. end
  162. end
  163. % ==================================================
  164. function [L1,L2]=crossgens(X1,X2)
  165. % Usage:[L1,L2]=crossgens(X1,X2)
  166. s=randomize([2:12]')';
  167. n1=min(s(1),s(11));n2=max(s(1),s(11));
  168. X3=X1;X4=X2;
  169. for i=n1:n2
  170.     for j=1:13
  171.         if X2(i)==X3(j)
  172.             X3(j)=0;
  173.         end
  174.         if X1(i)==X4(j)
  175.             X4(j)=0;
  176.         end
  177.     end
  178. end
  179. j=13;k=13;
  180. for i=12:-1:2,
  181.     if X3(i)~=0,
  182.         j=j-1;
  183.         t=X3(j);X3(j)=X3(i);X3(i)=t;
  184.     end
  185.     if X4(i)~=0,
  186.         k=k-1;
  187.         t=X4(k);X4(k)=X4(i);X4(i)=t;
  188.     end
  189. end
  190. for i=n1:n2
  191.     X3(2+i-n1)=X2(i);
  192.     X4(2+i-n1)=X1(i);
  193. end
  194. L1=X3;L2=X4;
  195. end
GMT+8, 2025-1-10 11:26 , Processed in 0.091788 second(s), 19 queries , Gzip On.
