查看: 2744|回复: 2
[控制系统类] simulink仿真模糊控制器到中途就停止了,怎么解决?
发表于 2011-5-10 19:56 | 显示全部楼层 |阅读模式
出现以下警报是什么意思?arning: Unable to reduce the step size without violating a minimum step size of 5.452311687220685e-013 at time 153.468930517968 for model 'b'.
Warning: Next step size (5.452311687220685e-013) is smaller than minimum step size (5e-013) at time 153.468930517968 because distance between zero crossings is smaller than the minimum step size.
跪求高手帮忙!
 楼主| 发表于 2011-5-10 20:17 | 显示全部楼层
请给位高手帮帮忙!讨论一下,我在线等!
发表于 2011-5-11 11:36 | 显示全部楼层
一般调试参数即可
GMT+8, 2024-11-28 19:00 , Processed in 0.056529 second(s), 17 queries , Gzip On.
