查看: 1162|回复: 1
[结构分析] time 是 时间???? 还是 倍数????
发表于 2011-5-3 01:23 | 显示全部楼层 |阅读模式
For the Damping method, the Damping Factor needs to be specified. The damping factor is the value that ANSYS uses to calculate stabilization forces for all subsequent substeps. This value is greater than 0.
There are three options for Activation For First Substep control:
  • No - Stabilization is not activated for the first substep even when it does not converge after the minimal allowed time increment is reached (Default).
  • On Non-convergence - Stabilization is activated for the first substep if it still does not converge after the minimal allowed time increment is reached. Use this option for the first load step only.
  • Yes - Stabilization is activated for the first substep. Use this option if stabilization was active for the previous load step Key = Constant.
发表于 2011-5-3 10:39 | 显示全部楼层
time increment :时间步长。
GMT+8, 2025-1-26 03:06 , Processed in 0.070841 second(s), 17 queries , Gzip On.
