查看: 2652|回复: 13
[小波] 小波包能量谱轴承故障诊断
发表于 2011-5-2 22:04 | 显示全部楼层 |阅读模式
load 200
fs=12000;
N=2048*4;
t=(0:1/fs:(N-1)/fs);
x=X200_DE_time ;
data=x(1:N,1)';
%jiang  zao
[thr,sorh,keepapp]=ddencmp('den','wv',data);   %去噪
data1=wdencmp('gbl',data,'sym1',2, thr,sorh,keepapp);
wpt=wpdec(data1,3,'db5');  %三层小波包分解
%节点 31
c31=wpcoef(wpt,[3,1]); %重构节点31
c31=abs(c31);
m31=mean(c31);   %求均值
a31=var(c31);%求方差
thr31=m31+a31%求阈值
for i=1:1024;
   if c31(i)<thr31;
    c31(i)=0;
e31=0;
for i=1:1024;
    e31=e31+(c31(i))^2;%节点31能量
%节点32
c32=wpcoef(wpt,[3,2]);
c32=abs(c32);
m32=mean(c32);
a32=var(c32);
thr32=m32+a32
for i=1:1024;
   if c32(i)<thr32;
    c32(i)=0;
e32=0;
for i=1:1024;
    e32=e32+(c32(i))^2;
%节点 33
c33=wpcoef(wpt,[3,3]);
c33=abs(c33);
m33=mean(c33);
a33=var(c33);
thr33=m33+a33
for i=1:1024;
   if c33(i)<thr33;
    c33(i)=0;
e33=0;
for i=1:1024;
    e33=e33+(c33(i))^2;
%jiedian 34
c34=wpcoef(wpt,[3,4]);
c34=abs(c34);
m34=mean(c34);
a34=var(c34);
thr34=m34+a34
for i=1:1024;
   if c34(i)<thr34;
    c34(i)=0;
e34=0;
for i=1:1024;
    e31=e34+(c34(i))^2;
%jiedian 35
c35=wpcoef(wpt,[3,5]);
c35=abs(c35);
m35=mean(c35);
a35=var(c35);
thr35=m35+a35
for i=1:1024;
   if c35(i)<thr35;
    c35(i)=0;
e35=0;
for i=1:1024;
    e35=e35+(c35(i))^2;
%jiedian 36
c36=wpcoef(wpt,[3,6]);
c36=abs(c36);
m36=mean(c36);
a36=var(c36);
thr36=m36+a36
for i=1:1024;
   if c36(i)<thr36;
    c36(i)=0;
e36=0;
for i=1:1024;
    e36=e36+(c36(i))^2;
%jiedian 37
c37=wpcoef(wpt,[3,7]);
c37=abs(c37);
m37=mean(c37);
a37=var(c37);
thr37=m37+a37
for i=1:1024;
   if c37(i)<thr37;
    c37(i)=0;
e37=0;
for i=1:1024;
    e37=e37+(c37(i))^2;
disp(e31);disp(e32);disp(e33);disp(e34);disp(e35);disp(e36);disp(e37);
比较能量大小,选取能量大的频带进行fft
c36=wprcoef(wpt,[3,6]);
c36=abs(c36);
p=c36.^2;
nfft=1024*8;fs=12000;
ff=abs(fft(p));
f=fs*(0:nfft/2-1)/nfft;figure(2);
plot(f,ff(1:nfft/2))
axis([0,800,0,60])
故障频谱图如下
请同仁看看 我哪里不对啊
 楼主| 发表于 2011-5-2 22:04 | 显示全部楼层
程序只看前面我注释的就可以,很好理解 谢谢阅读
 楼主| 发表于 2011-5-2 22:05 | 显示全部楼层
其中 轴承为外环故障 故障频率为103HZ
发表于 2011-5-3 08:42 | 显示全部楼层
 楼主| 发表于 2011-5-3 19:06 | 显示全部楼层
回复 4 # liu222bing 的帖子
是啊  你也是应用小波做轴承故障的?
 楼主| 发表于 2011-5-3 22:04 | 显示全部楼层
对于西储大学的数据 你是怎么用的?我做频谱分析后 怎么做的结果不理想啊?
 楼主| 发表于 2011-5-3 22:05 | 显示全部楼层
导入的形式是这样子的吗?
load 200
fs=12000;
N=2048*4;
x=X200_FE_time ;
data=x(1:N,1)';
发表于 2011-5-4 09:01 | 显示全部楼层
是啊  你也是应用小波做轴承故障的?
我现在用小波做的感觉比HHT效果好啊
导入的形式是这样子的吗?
这个可以啊,可以加QQ吗?更方便交流513088330
 楼主| 发表于 2011-5-4 20:57 | 显示全部楼层
回复 9 # liu222bing 的帖子
我的qq是422858431 交流一下
发表于 2012-2-25 14:50 | 显示全部楼层
回复 8 # liu222bing 的帖子
腻用HHT是怎么做的啊?我是初学者,可以加我吗?373071914
发表于 2012-3-10 11:45 | 显示全部楼层
重构节点的函数不应该是wprcoef吗?
发表于 2012-3-22 11:56 | 显示全部楼层
我也想和大家交流一下,
发表于 2012-4-13 08:30 | 显示全部楼层
重构节点函数改为wprcoef,结果就正确了
GMT+8, 2025-1-10 01:24 , Processed in 0.075683 second(s), 22 queries , Gzip On.
