查看: 1532|回复: 0
[材料与接触] 电磁式位移传感器骨架与连杆接触分析问题求助
发表于 2011-4-30 21:20 | 显示全部楼层 |阅读模式
在对电磁式位移传感器骨架与连杆进行接触分析时,每次到运行到ESURF这一步时,都提示 there are no elements defined,the ESURF command is ignored。
请问问题出在哪???
命令流如下
finish
/CLEAR
/filname,1-1,1
/PREP7
VSEL,S,,,1
NSLV,S,1
CM,ke,NODE
VSEL,S,,,4
NSLV,S,1
CM,gan,NODE
MP,MU,1
MAT,1
REAL,3
ET,2,170
ET,3,174
R,3,,,1,-0.001,0,0.5
RMORE,0.001,0.0005,,,,1000
KEYOPT,3,5,2
KEYOPT,3,9,0
KEYOPT,3,10,1
!Generate the target surface
NSEL,S,NODE,,ke
CM,_TARGET,NODE
TYPE,2
ESLN,S,0
ESURF
!Generate the contact surface
NSEL,S,NODE,,GAN
CM,_CONTACT,NODE
TYPE,3
ESLN,S,0
ESURF
ALLSEL
FINISH
GMT+8, 2025-1-26 03:05 , Processed in 0.088181 second(s), 18 queries , Gzip On.
