查看: 1949|回复: 5
[ansys] 瞬态声场分析后处理
发表于 2011-4-28 14:47 | 显示全部楼层 |阅读模式
请教各位老师,我用那个平板声学例子,加了瞬态激励,查看随时间变化的声压值,为何都是零?加了一个阶跃激励,分十个子步。
 楼主| 发表于 2011-5-2 10:18 | 显示全部楼层
求高手指导啊
 楼主| 发表于 2011-5-3 16:07 | 显示全部楼层
/PREP7
ET,1,SOLID45                   !壳单元 类型1
ET,2,FLUID30                   ! acoustic fluid element with ux & uy(0-Structure present at interface (unsymmetric element matrix))
ET,3,130                       ! acoustic infinite line element
r,3,0.3,0,0
ET,4,FLUID30,,1,0              ! acoustic fluid element without ux & uy(1-No structure at the interface (symmetric element matrix))
! material properties
!材料1为铁
MP,EX,1,2.1E11
MP,DENS,1,7800
MP,NUXY,1,0.3
!材料2为空气介质
MP,DENS,2,1.21
MP,SONC,2,344
!建立模型
wprot,0,-90,0
SPHERE,,0.3,0,180                      !SPHERE, RAD1, RAD2, THETA1, THETA2
wprot,0,90,0
BLOCK,0,0.1, -0.002, 0.002, -0.1, 0    !BLOCK, X1, X2, Y1, Y2, Z1, Z2
BLOCK,-0.1,0, -0.002, 0.002, -0.1, 0
VGLUE,2,3
VOVLAP,1,2                             !Overlaps volumes
VOVLAP,3,4
!对编号为2的体划分网格
lesize,9,,,20,1
lesize,19,,,20,1
lesize,14,,,20,1
lesize,18,,,20,1
lesize,11,,,20,1
lesize,16,,,20,1
lesize,12,,,20,1
lesize,17,,,20,1
lesize,8,,,4,1
lesize,15,,,4,1
lesize,13,,,4,1
lesize,10,,,4,1
VSEL,s,,,2
VATT,1,,1
mshkey,1    !Specifies whether free meshing or mapped meshing should be used to mesh a model.1— Use mapped meshing.
VMESH,2
alls
!对编号为4的体划分网格
lesize,32,,,20,1
lesize,31,,,20,1
lesize,35,,,20,1
lesize,33,,,20,1
lesize,28,,,20,1
lesize,34,,,20,1
lesize,20,,,4,1
lesize,27,,,4,1
VSEL,s,,,4
VATT,1,,1
VMESH,4
alls
!对编号为1的体划分网格(此步骤划分网格需要手动进行)
VSEL,s,,,1
VATT,2,,2  !指定的材料属性为空气介质(与结构耦合)
SMRT,1
VMESH,1
alls
!修改不与平板(结构)接触单元的材料类型类型为空气介质(不与结构耦合)
esel,s,type,,1
nsle,s
esln,s,0
nsle,s
esel,inve
nsle,s
emodif,all,type,4
alls
!在边界生成吸收单元。(使用单元fluid130)
Asel,s,,,1,2
NSLA,S,1
type,3
real,3
mat,2
esurf                 !Generates elements overlaid on the free faces of existing selected elements.
alls
!建立流-固接触面
Asel,s,,,8
Asel,A,,,10
Asel,A,,,7
Asel,A,,,5
Asel,A,,,19
Asel,A,,,15
Asel,A,,,17
Asel,A,,,20
NSLA,S,1
esel,s,type,,2
sf,all,fsi,1
alls
/solu
antype,trans
trnopt,full,nodamp
da,6,all
da,18,all
time,0.02
nsubst,10
kbc,1
outpr,basic,1
outres,all,1
f,1,fy,10
alls
solve
/post26
nsol,2,4632,pres,pres
plvar,2
得出某节点声压随时间变化曲线,但是某时间点的声压级却全是灰色。
发表于 2011-5-3 21:10 | 显示全部楼层
回复 1 # jarvisliu 的帖子
呵呵,子步再多一些试试.
 楼主| 发表于 2011-5-4 14:57 | 显示全部楼层
回复 4 # w89986581 的帖子
子步多了会不会只是时间上分辨的更清晰些,我没见过瞬态的例子,所以不知道还能得出些什么结果,请老师指导。
发表于 2011-5-12 17:00 | 显示全部楼层
回复 5 # jarvisliu 的帖子
关于瞬态分析,我只参考LMS例子做过一次.根据差分表达式,可知瞬态分析对步长是要求的,这方面文章应该不少吧.
GMT+8, 2025-1-12 01:40 , Processed in 0.077420 second(s), 21 queries , Gzip On.
