查看: 1989|回复: 2
[前后处理] proe模型导入ansys警告内存不足,允许模型修复
发表于 2011-4-27 07:16 | 显示全部楼层 |阅读模式
  将proe模型导入ansys时老是出现问题弹出提示:
  通过IGES方式导入,模型修复默认的关闭状态没有问题,一旦设置成打开就提示内存不足:
Warning:
  This model requires more scratch space than currently available.Please shutdown other running applications and click RETRY to have ANSYS try to get more memory.Current allocation attempt:80496904words(307MB).
Fatal Error:
       Ansys has currently allocated 716 MB and was not able to allocate enough additional memory in order to  proceed. Please increase the virtual memory and rerun Ansys.Problem terminated.
  虚拟内存开了非常大,系统的/3GB也开了,开机之后除了Ansys什么都没开,Ansys Product Lancher里内存调用改成1400多还是不行。
  求高手指教,谢!
发表于 2011-4-29 08:45 | 显示全部楼层
换个格式试试!
 楼主| 发表于 2011-4-29 22:40 | 显示全部楼层
回复 2 # sc493 的帖子
我也听说了IGES导入出错特别多,但是别的好像都不能进行模型修复……现在用x_t的导入一下看看效果吧
GMT+8, 2025-1-26 03:24 , Processed in 0.102785 second(s), 17 queries , Gzip On.
