查看: 2251|回复: 2
[结构分析] Ramped Effects, No Ramping, 这两个是什么东西???
发表于 2011-4-24 13:48 | 显示全部楼层 |阅读模式
This setting is useful to make sure initial contact occurs even if any gaps are present (as long as they are within the pinball region). Without using this setting, the bodies may fly apart if any initial gaps exist. Although any initial gaps are ignored, gaps can still form during loading for the nonlinear contact types. This treatment is used inherently for the linear contact types (Bonded and No Separation), which is the reason why Interface Treatment is not displayed for these contact types. For nonlinear contact types (Frictionless, Rough, and Frictional), Interface Treatment is displayed where the choices are Adjust to Touch, Add Offset, Ramped Effects, and Add Offset, No Ramping.
Ramped Effects,
No Ramping,
这两个是什么东西???
发表于 2011-4-24 16:33 | 显示全部楼层
Add Offset, Ramped Effects 以斜坡方式施加偏移
Add Offset, No Ramping.   以阶跃方式(step)施加偏移
 楼主| 发表于 2011-4-25 15:26 | 显示全部楼层
麻烦解释一下! 什么是.......(最好有图)
No Ramping > 应该翻译成 "无"斜坡 吧?
GMT+8, 2025-1-27 20:55 , Processed in 0.088325 second(s), 17 queries , Gzip On.
