查看: 1172|回复: 0
[结构分析] 网格将包含一个单层与沿着这个方向下降的所有中端节点的实体单元
发表于 2011-4-8 15:44 | 显示全部楼层 |阅读模式
Gasket Bodies
You can conveniently specify a solid body to be treated as a gasket by settings its Stiffness Behavior to Gasket. A Gasket body will be meshed with special elements that have a preferential or sweep direction. The mesh will consist of a single layer of solid elements with all mid-side nodes dropped along this direction. You must also specify a material with a valid gasket model in Engineering Data.
请问这段话是什么意思? 什么是 单层 (single layer) ?
GMT+8, 2025-1-11 12:48 , Processed in 0.063779 second(s), 17 queries , Gzip On.
