查看: 1725|回复: 3
[HHT] 谁有HHT中toimage和disp_hhs的源程序
发表于 2011-3-24 17:27 | 显示全部楼层 |阅读模式
谁有HHT中toimage和disp_hhs的源程序  麻烦上传一份吧 谢谢
发表于 2011-3-30 11:20 | 显示全部楼层
function [im,tt,ff] = toimage(A,f,varargin)
DEFSPL = 400;
error(nargchk(2,5,nargin));
switch nargin
  case 2
    t = 1:size(A,2);
    sply = DEFSPL;
    splx = length(t);
  case 3
    if isscalar(varargin{1})
      t = 1:size(A,2);
      splx = length(t);
      sply = varargin{1};
    else
      t = varargin{1};
      splx = length(t);
      sply = DEFSPL;
  case 4
      t = 1:size(A,2);
      sply = varargin{1};
      splx = varargin{2};
    else
      t = varargin{1};
      sply = varargin{2};
      splx = length(t);
  case 5
    t = varargin{1};
    splx = varargin{2};
    sply = varargin{3};
if isvector(A)
  A = A(:)';
  f = f(:)';
if issparse(A) || ~isreal(A) || length(size(A)) > 2
  error('A argument must be a real matrix')
if issparse(f) || ~isreal(f) || length(size(f)) > 2
  error('f argument must be a real matrix')
if any(size(f)~=size(A))
  error('A and f matrices must have the same size')
if issparse(t) || ~isreal(t) || ~isvector(t) || length(t)~=size(A,2)
  error('t argument must be a vector and its length must be the number of columns in A and f inputs')
if ~isscalar(splx) || ~isreal(splx) || splx ~= floor(splx) || splx <= 0
  error('splx argument must be a positive integer')
if ~isscalar(sply) || ~isreal(sply) || sply ~= floor(sply) || sply <= 0
if any(diff(diff(t))) && splx ~= length(t)
  warning('toimage:nonuniformtimeinsants','When splx differs from length(t), the function only works for equally spaced time instants. You may consider reformating your data (using e.g. interpolation) before using toimage.')
f = min(f,0.5);
f = max(f,0);
indf = round(2*f*(sply-1)+1);
indt = repmat(round(linspace(1,length(t),splx)),size(A,1),1);
im = accumarray([indf(:),indt(:)],A(:),[sply,splx]);
indt = indt(1,:);
tt = t(indt);
ff = (0:sply-1)*0.5/sply+1/(4*sply);
function disp_hhs(im,t,inf)
% DISP_HHS(im,t,inf)
% displays in a new figure the spectrum contained in matrix "im"
% (amplitudes in log).
% inputs : - im : image matrix (e.g., output of "toimage")
% - t (optional) : time instants (e.g., output of "toimage")
% - inf (optional) : -dynamic range in dB (wrt max)
% default : inf = -20
% utilisation : disp_hhs(im) ; disp_hhs(im,t) ; disp_hhs(im,inf)
% disp_hhs(im,t,inf)
figure
colormap(bone)
colormap(1-colormap);
if nargin==1
inf=-20;
t = 1:size(im,2);
if nargin == 2
if length(t) == 1
inf = t;
t = 1:size(im,2);
else
inf = -20;
if inf >= 0
error('inf doit etre < 0')
M=max(max(im));
im = log10(im/M+1e-300);
inf=inf/10;
imagesc(t,fliplr((1:size(im,1))/(2*size(im,1))),im,[inf,0]);
set(gca,'YDir','normal')
xlabel(['time'])
ylabel(['normalized frequency'])
title('Hilbert-Huang spectrum')
发表于 2014-2-26 14:22 | 显示全部楼层
你好,我想问下用网上的程序做希尔伯特谱时为什么会出现下面的图形,而不是网上的蓝色背景的图形,先谢谢了哈~
N=1000;
n=1:N;
fs=1000;
t=n/fs;
fx=10;
fy=50;
x=cos(2*pi*fx*t);
y=10*cos(2*pi*fy*t);
z=x+y;
data=z;
imf=eemd(data,0.2,100);
[A,f,t]=hhspectrum(imf);
[E,t,Cenf]=toimage(A,f);
disp_hhs(E);
GMT+8, 2025-1-6 13:40 , Processed in 0.086432 second(s), 25 queries , Gzip On.
