查看: 3041|回复: 4
[材料与接触] ANSYS实例命令流程序_接触分析例题_岩土方面
发表于 2011-3-13 07:49 | 显示全部楼层 |阅读模式
例子1是为了获得初始应力,计算可以完成。命令流为:
  1. !以便获得初始应力,收敛!!考虑土与岩石之间的摩擦,点面接触
  2. fini !考虑土体的相互作用。自由划分网格,局部细化,不收敛!!!!!!!!!!!
  3. /cle
  4. /filname,diji11
  5. /title,地基应力、应变的分布规律
  6. /units,si
  7. /PREP7
  8. !ET,1,PLANE2
  9. ET,1,PLANE42
  10. KEYOPT,1,3,2
  11. KEYOPT,1,5,0
  12. KEYOPT,1,6,0
  13. MP,EX,1,8e9 !岩石性质
  14. MP,PRXY,1,0.29
  15. MP,DENS,1,2600
  16. MP,EX,2,5.0e7 !风化槽土体性质?
  17. MP,PRXY,2,0.25
  18. TB,dp,2
  19. TBDATA,1,15e3,20,0
  20. MP,DENS,2,2000
  21. et,2,contac48,,,1
  22. mp,mu,3,2.5
  23. r,1,5.0e7,5.0e6,0.01,1.0,0.001,0.001
  24. r,2,5.0e7,5.0e6,0.01,1.0,0.001,0.001
  25. K,1,0,0,0,
  26. K,2,2.5,-12,0,
  27. K,3,6.5,-12,0,
  28. K,4,13.5,-26.5,0,
  29. K,5,20,-30,0,
  30. K,6,24.5,-27,0,
  31. K,7,31.5,-12,0
  32. K,8,35.5,-12,0,
  33. K,9,38,0,0,
  34. k,10,-40,0,0,
  35. k,11,-40,-60,0,
  36. k,12,80,-60,0,
  37. k,13,80,0,0,
  38. K,14,6.5,-12,0,
  39. K,15,13.5,-26.5,0,
  40. K,16,20,-30,0,
  41. K,17,24.5,-27,0,
  42. K,18,31.5,-12,0
  43. *do,i,1,8
  44. lstr,i,i+1
  45. *enddo
  46. LSTR,1,10
  47. *do,i,10,12
  48. lstr,i,i+1
  49. *enddo
  50. LSTR,13,9
  51. *do,i,14,17
  52. lstr,i,i+1
  53. *enddo
  54. LARC,14,18,16,14.57
  55. FLST,2,13,4
  56. *do,i,1,13
  57. FITEM,2,i
  58. *enddo
  59. AL,P51X
  60. FLST,2,5,4
  61. *do,i,14,18
  62. FITEM,2,i
  63. *enddo
  64. AL,P51X
  65. asel,s,area,,1
  66. aatt,1,,1
  67. asel,s,area,,2
  68. aatt,2,,1
  69. esize,4
  70. asel,all
  71. amesh,all
  72. lsel,s,line,,3,4,1
  73. nsll,s,1
  74. CM,_TARGET1,node
  75. lsel,s,line,,14,15,1
  76. nsll,s,1
  77. CM,_CONTACT1,node
  78. lsel,s,line,,5,6,1
  79. nsll,s,1
  80. CM,_TARGET2,node
  81. lsel,s,line,,16,17,1
  82. nsll,s,1
  83. CM,_CONTACT2,node
  84. TYPE,2
  85. mat,3
  86. real,1
  87. gcgen,_CONTACT1,_TARGET1
  88. real,2
  89. gcgen,_CONTACT2,_TARGET2
  90. fini
  91. FINISH
  92. /SOLU
  93. antype,static
  94. nlgeom,on
  95. nropt,full,,off
  96. neqit,40
  97. pred,on
  98. autots,on
  99. time,1
  100. nsubst,100,1000,10
  101. alls
  102. LSEL,s,line,,10,12,2
  103. CM,_Y,LINE
  104. CMSEL,,_Y
  105. DL,_Y, ,ux,0,0
  106. LSEL,s,line,,11
  107. CM,_Y,LINE
  108. CMSEL,,_Y
  109. DL,_Y, ,uy,0,0
  110. alls
  111. acel,,9.8
  112. iswrite,on
  113. lnsrch,on
  114. outres,all,all
  115. solve
 楼主| 发表于 2011-3-13 07:50 | 显示全部楼层
例2:
  1. !读入初始应力,收敛!!考虑土和混凝土与岩石之间的摩擦,点面接触
  2. fini !考虑土体和混凝土之间的相互作用。不收敛!!!!!!!!!!!
  3. /cle
  4. /filname,diji
  6. /units,si
  7. /PREP7
  8. ET,1,PLANE42
  9. KEYOPT,1,3,2
  10. KEYOPT,1,5,0
  11. KEYOPT,1,6,0
  12. MP,EX,1,8e9 !岩石性质
  13. MP,PRXY,1,0.29
  14. MP,DENS,1,2600
  15. MP,EX,2,5.0e7 !风化槽土体性质?
  16. MP,PRXY,2,0.25
  17. TB,dp,2
  18. TBDATA,1,15e3,20,0
  19. MP,DENS,2,2000
  20. MP,EX,3,2.55e10 !混凝土性质
  21. MP,PRXY,3,0.167
  22. MP,DENS,3,2400
  23. et,2,contac48,,,1
  24. mp,mu,4,2.5
  25. mp,mu,5,4.5
  26. mp,mu,6,3.0
  27. r,1,5.0e7,5.0e6,0.01,1.0,0.001,0.001
  28. r,2,5.0e7,5.0e6,0.01,1.0,0.001,0.001
  29. r,3,8.0e9,8.0e8,0.01,1.0,0.001,0.001
  30. r,4,8.0e9,8.0e8,0.01,1.0,0.001,0.001
  31. r,5,5.0e7,5.0e6,0.01,1.0,0.001,0.001
  32. K,1,0,0,0,
  33. K,2,2.5,-12,0,
  34. K,3,6.5,-12,0,
  35. K,4,13.5,-26.5,0,
  36. K,5,20,-30,0,
  37. K,6,24.5,-27,0,
  38. K,7,31.5,-12,0
  39. K,8,35.5,-12,0,
  40. K,9,38,0,0,
  41. k,10,-40,0,0,
  42. k,11,-40,-60,0,
  43. k,12,80,-60,0,
  44. k,13,80,0,0,
  45. K,14,6.5,-12,0,
  46. K,15,13.5,-26.5,0,
  47. K,16,20,-30,0,
  48. K,17,24.5,-27,0,
  49. K,18,31.5,-12,0
  50. K,19,0,0,0,
  51. K,20,2.5,-12,0,
  52. K,21,6.5,-12,0,
  53. K,22,31.5,-12,0
  54. K,23,35.5,-12,0,
  55. K,24,38,0,0,
  56. K,25,20,0,0,
  57. *do,i,1,8
  58. lstr,i,i+1
  59. *enddo
  60. LSTR,1,10
  61. *do,i,10,12
  62. lstr,i,i+1
  63. *enddo
  64. LSTR,13,9
  65. *do,i,14,17
  66. lstr,i,i+1
  67. *enddo
  68. LARC,14,18,16,14.57
  69. *do,i,19,20
  70. lstr,i,i+1
  71. *enddo
  72. LARC,21,22,16,14.57
  73. *do,i,22,24
  74. lstr,i,i+1
  75. *enddo
  76. LSTR,25,19
  77. FLST,2,13,4
  78. *do,i,1,13
  79. FITEM,2,i
  80. *enddo
  81. AL,P51X
  82. FLST,2,5,4
  83. *do,i,14,18
  84. FITEM,2,i
  85. *enddo
  86. AL,P51X
  87. FLST,2,7,4
  88. *do,i,19,25
  89. FITEM,2,i
  90. *enddo
  91. AL,P51X
  92. asel,s,area,,1
  93. aatt,1,,1
  94. asel,s,area,,2
  95. aatt,2,,1
  96. esize,4
  97. asel,s,area,,1,2
  98. amesh,all
  99. lsel,s,line,,3,4,1
  100. nsll,s,1
  101. CM,_TARGET1,node
  102. lsel,s,line,,14,15,1
  103. nsll,s,1
  104. CM,_CONTACT1,node
  105. lsel,s,line,,5,6,1
  106. nsll,s,1
  107. CM,_TARGET2,node
  108. lsel,s,line,,16,17,1
  109. nsll,s,1
  110. CM,_CONTACT2,node
  111. TYPE,2
  112. mat,4
  113. real,1
  114. gcgen,_CONTACT1,_TARGET1
  115. real,2
  116. gcgen,_CONTACT2,_TARGET2
  117. asel,s,area,,3
  118. aatt,3,,1
  119. esize,4
  120. amesh,all
  121. lsel,s,line,,1,8,7
  122. nsll,s,1
  123. CM,_TARGET3,node
  124. lsel,s,line,,19,23,4
  125. nsll,s,1
  126. CM,_CONTACT3,node
  127. lsel,s,line,,2,7,5
  128. nsll,s,1
  129. CM,_TARGET4,node
  130. lsel,s,line,,20,22,2
  131. nsll,s,1
  132. CM,_CONTACT4,node
  133. TYPE,2
  134. mat,5
  135. real,3
  136. gcgen,_CONTACT3,_TARGET3
  137. real,4
  138. gcgen,_CONTACT4,_TARGET4
  139. lsel,s,line,,18
  140. nsll,s,1
  141. CM,_TARGET5,node
  142. lsel,s,line,,21
  143. nsll,s,1
  144. CM,_CONTACT5,node
  145. TYPE,2
  146. mat,6
  147. real,5
  148. gcgen,_CONTACT5,_TARGET5
  149. fini
  150. /SOLU
  151. antype,static
  152. nlgeom,on
  153. nropt,full,,off
  154. neqit,40
  155. pred,on
  156. autots,on
  157. time,1
  158. esel,s,,,1,451
  159. nsle,s
  160. isfile,read,diji11,ist,,1
  161. nsubst,100,1000,10
  162. LSEL,s,line,,10,12,2
  163. CM,_Y,LINE
  164. CMSEL,,_Y
  165. DL,_Y, ,ux,0,0
  166. LSEL,s,line,,11
  167. CM,_Y,LINE
  168. CMSEL,,_Y
  169. DL,_Y, ,uy,0,0
  170. acel,,9.8
  171. alls
  172. LSEL,s,line,,25
  173. CM,_Y1,LINE
  174. CMSEL,,_Y1
  175. SFL,_Y1,PRES,4.5e5,6e5,
  176. LSEL,s,line,,24
  177. CM,_Y1,LINE
  178. CMSEL,,_Y1
  179. SFL,_Y1,PRES,4.5e5,4.5e5
  180. alls
  181. iswrite,on
  182. lnsrch,on
  183. outres,all,all
  184. solve
发表于 2011-4-5 19:42 | 显示全部楼层
支持一下,看了你好多帖子,希望以后可以看到你更多的帖子
发表于 2011-4-22 20:14 | 显示全部楼层
太感谢了,呵呵
发表于 2012-3-26 19:19 | 显示全部楼层
回复 2 # Chelsea 的帖子
楼主你好,我在做一个柔柔接触的时候,分析结果又很大的刚体位移,不知如何解决,能请您帮助看看吧
我固定筒中的内核的一端,然后在内核的另一端施加位移荷载。几个荷载步运行后发现DMX很大,可是我是假的位移荷载只有10个单位,查阅资料说是刚体位移,请问这个问题如何解决啊。
不知道是不是我的命令流有问题啊?
GMT+8, 2025-1-11 04:24 , Processed in 0.085251 second(s), 21 queries , Gzip On.
